How to find out proper pins for TTL connection
Today i have set up my first StromLeser device in the setup One wifi and the other TTL .
With wifi was easy but with ttl it was hard to find out what is the proper IN and OUT pins behind each connector ( may be i am using terms wrong - i am total noob on this topic but it is about this https://julianehehl.de/voltaik/stromleser/Anleitung_%20Stromleser%20WIFI%20einrichten%20und%20TTL%20Lesekopf%20hinzufügen%20-%20mi.pdf docu and picture near “Schritt 11: Stromleser TTL anschließen“ ) .
I have tried all possible combinations for my second leser untiil not found on paper documentation small sticker saying that
Correct  ( for top right )
+2,4,s,16,9600,eHZ_TTL,5
And this from docu not correct
+2,5,s,16,9600,eHZ_TTL,4
it solved my problem . so right now i have working configuration like this
+1,3,s,16,9600,eHZ,1
1,770701000f0700ff@1,akt. Leistung2,W,Power2,0
2,770701000f0700ff@1,akt. Leistung2,W,Power2,0
I plan to buy extra TTL reader for the 3rd strom-zähler
And now come the main question . Is there any possibility to detect what PINS my other 3 slots on my wifi-stromlerer are using ? May be via debugging console or some other way .
Thank you
Hello,
you will see the pins in the picture below.
but for the third , forth and with wyou hav veto place a minus infrot of the number (pin/port).
like this entries:
+3,-20,s,16,9600,OG,21
+4,-6,s,16,9600,DG,7
Best regards
Bernd
Ich habe ein ähnliches Problem:
Der erste Zähler ISKRA MT681 funktioniert einwandfrei.
Der zweite TTL-Zähler ISKRA MT691 gibt nur Nullwerte zurück.
Er ist, wenn man auf den ersten Zähler schaut, oben rechts eingesteckt.
Meine Konfiguration:
+1,3,s,16,9600,MT681,1
+2,5,s,16,9600,MT691,4
1,=h–
1,77070100240700ff@1,Current Consumption P1,W,Power_p1,0
1,77070100380700ff@1,Current Consumption P2,W,Power_p2,0
1,770701004c0700ff@1,Current Consumption P3,W,Power_p3,0
1,77070100000009ff@#,Service ID,Meter_id,0
2,=h–
2,=h–
2,77070100000009ff@#,Service ID,Meter_id,0
1,=h–
2,=h–
2,=h–
Ich habe den Fehler über den Beitrag
How to find out proper pins for TTL connection gefunden:
Die Zeile für den zweiten Zähler muss lauten:
+2,4,s,16,9600,MT691,5 statt
An der Stelle ist die Doku falsch!
