Iskra MT 631 liefert falsche Daten
ich habe heute den Lesekopf bekommen und eingebaut.
Leider stimmen die gelieferten Werte absolut nicht.
Hier mal ein HexDump des Zählers:
17:14:39.371:7707010060320101010101010449534b01
17:14:39.373:77070100600100ff010101010b0a0149534b000584fb4001
17:14:39.421:77070100010800ff65001c810401621e520363012b01
17:14:40.321:77070100020800ff0101621e5203620001010163a22100760500504fc56200620072630201710163
17:14:40.323:77010b0a0149534b000584fb40070100620affff72620165001ac32f74
17:14:40.371:7707010060320101010101010449534b01
17:14:40.373:77070100600100ff010101010b0a0149534b000584fb4001
17:14:40.421:77070100010800ff65001c810401621e520363012b01
17:14:41.290:77070100020800ff0101621e5203620001010163227100760500504fc86200620072630201710163
17:14:41.339:77010b0a0149534b000584fb40070100620affff72620165001ac33074
17:14:41.341:7707010060320101010101010449534b01
17:14:41.389:77070100600100ff010101010b0a0149534b000584fb4001
17:14:41.391:77070100010800ff65001c810401621e520363012b01
17:14:42.291:77070100020800ff0101621e52036200010101631ff400760500504fcb6200620072630201710163
17:14:42.340:77010b0a0149534b000584fb40070100620affff72620165001ac33174
17:14:42.342:7707010060320101010101010449534b01
17:14:42.390:77070100600100ff010101010b0a0149534b000584fb4001
17:14:42.392:77070100010800ff65001c810401621e520363012b01
17:14:43.297:77070100020800ff0101621e5203620001010163320e00760500504fce6200620072630201710163
17:14:43.347:77010b0a0149534b000584fb40070100620affff72620165001ac33274
17:14:43.349:7707010060320101010101010449534b01
17:14:43.397:77070100600100ff010101010b0a0149534b000584fb4001
17:14:43.399:77070100010800ff65001c810401621e520363012b01
17:14:44.297:77070100020800ff0101621e52036200010101636f1800760500504fd16200620072630201710163
17:14:44.347:77010b0a0149534b000584fb40070100620affff72620165001ac33374
17:14:44.349:7707010060320101010101010449534b01
17:14:44.397:77070100600100ff010101010b0a0149534b000584fb4001
17:14:44.399:77070100010800ff65001c810401621e520363012b01
17:14:45.302:77070100020800ff0101621e5203620001010163ef4800760500504fd46200620072630201710163
17:14:45.352:77010b0a0149534b000584fb40070100620affff72620165001ac33474
17:14:45.354:7707010060320101010101010449534b01
17:14:45.355:77070100600100ff010101010b0a0149534b000584fb4001
17:14:45.402:77070100010800ff65001c810401621e520363012b01
Ich habe das orginale Script hier von der Seite genommen und auch mal das hier:
+1,3,s,0,9600,NETZ,1
+2,5,s,0,9600,HAUS,4
1,77070100100700ff@1,Leistung,W,Power_cur,0
1,77070100240700ff@1,Leistung L1,W,Power_p1,0
1,77070100380700ff@1,Leistung L2,W,Power_p2,0
1,770701004c0700ff@1,Leistung L3,W,Power_p3,0
1,77070100010800ff@1000,Bezug,kWh,Total_in,4
1,77070100020800ff@1000,Einspeisung,kWh,Total_out,4
1,77070100000009ff@#,Service ID,Meter_id,0
2,=h=====================================
2,77070100100700ff@1,Leistung,W,Power_cur,0
2,77070100240700ff@1,Leistung L1,W,Power_p1,0
2,77070100380700ff@1,Leistung L2,W,Power_p2,0
2,770701004c0700ff@1,Leistung L3,W,Power_p3,0
2,77070100010800ff@1000,Bezug,kWh,Total_in,4
2,77070100020800ff@1000,Einspeisung,kWh,Total_out,4
2,77070100000009ff@#,Service ID,Meter_id,0
Es wird aber nichts wirklich angezeigt.
Die Pin ist eingegeben und akzeptiert.
Hat wer eine Idee?
Gruß,
Ingo
Hallo, kannst du es zuerst mit 1 Stromzahler versuchen und prüfen, ob du korrekte Daten erhältst?
+1,3,s,0,9600,MT631,1
1,=soC,1024,0
1,=h—
1,77070100600100ff@#,Server ID,,server_id,0
Hi, Verbrauch (Gesamt) geht, Einspeisung bleibt auf 0, da keine Einspeisung vorhanden.
Leistung kommt auch 0. Ich denke, da gibt der Smarty nichts raus.
Ich habe dem Smarty mal geblickt, dass er INFO auf On stellen soll. Jetzt kommt auch die Leistung.
Liefert der MT631 auch die Leistungen der einzelnen Phasen? Wenn ja, wie sieht das Skript dazu aus?
Kann man auch Spannungen und Netzfrequenz bekommen?
